Purging
Some tables in the AutomationEdge database accumulate a large amount of data over time. To maintain optimal system performance, the records should be periodically purged.
Purging allows creation of a Purge Policy and Purge Schedule to periodically clean up the database tables. The process reduces database and disk space usage, thereby enhancing the performance of the AutomationEdge system.
Important:
  • Only a System Administrator can set a purge policy and schedule.
  • An Admin can only edit the purge policy at Tenant level and view the purge schedule.
  • An Admin can view and download the archives.
You can purge the following data tables:
  • Audit Logs
  • User Session History
  • Workflow Requests
  • Notification History
In the chapter, you will learn about how to create a purge policy and schedule the purging activity.
