Get Started
In the chapter, you will learn about logging on to AE server, modifying the default password, and understanding the user interface (UI). In addition, the chapter includes a brief overview of the AE user interface, which will help you work with AE with ease.
Log on to AutomationEdge
You can log on to AutomationEdge server in any one of the following two ways:
Important
If you are logging into AE for the first time, then you must change the default password to ensure security of the account.
Sign-in as AutomationEdge user
Log on to AutomationEdge server using your username and password.
To log on to the AutomationEdge:
  1. In the browser’s address bar, enter the AutomationEdge URL.The AutomationEdge login page appears.For example, http://localhost:8080/aeui.
AEUI
Figure: Login page
You will receive the username and password on your email address, if the System Administrator has configured the email settings and selected the Send verification link over email checkbox in the Add New User page. For details about email configuration and adding new users, see the System Administrator’s guide.
You can also enable co-branding. For information about enabling co-branding and configuring the co-branding logo, see the Configure AutomationEdge UI settings section in the AutomationEdge Installation Guide.
alt text
    UsernameEnter the name of the user with which you want to log on to the application.
    PasswordEnter the password to log on to the application.
    If the captcha property is enabled, that is, set to true in the aeui-config.properties file, then the captcha text appears on the login and forgot password pages. For more details, see the AutomationEdge Installation guide.
    # This key is used to enable Captcha for UI.
    If Value is true then Captcha will be enabled otherwise captcha is disabled.
    enableCaptcha = false
    Enter the captcha text along with the username and password, as shown in the following screenshot:
    AEUI
    Figure: Captcha
  2. Click Login. The Release Notes dialog appears.
    AEUI
    Figure : Release Notes: Informing what’s new in the current release
    • To dismiss the Release Notes dialog, click Close.
    • The dialog appears each time you log on to AE UI. However, if you select the Don't show this dialog again checkbox, then the dialog will not appear when you log on again.
    • After you select the checkbox, when you again log on to the AE UI you will see the Home page.
    • To view the dialog again, select What's New in v<current release> in User profile.
Sign-in with Single Sign-On (SSO)
If SSO is configured and your username is linked to an Identity Provider user, then you can sign in to AutomationEdge using the SSO link on the login page.
important
To better understand the SSO login process, the details are explained using Okta as the Identity Provider.
AutomationEdge also supports SSO with other Identity Providers, such as Keycloak and ADFS. For details about Identity Provider setups, see Appendix: SSO Identity Providers.
To sign-in with SSO link:
  1. On the login page, click Sign In with SSO. The Organization Code dialog appears.
    release notes
    Figure: Organization Code dialog
  2. In Organization Code, enter your organization code, and then click Continue. The Identity Provider login page appears. For example, the Okta login page.
release notes
Figure : Okta: Identity Provider login page
  1. On the login page, enter the Identity Provider username and password linked with the AE SSO user, and then click Sign In. You will see the Release Notes dialog.
    Each time you log on to AutomationEdge, you will see the Release Notes dialog. However, if you select the Don’t show this dialog again checkbox, then the dialog will not appear, and you will see the Home page instead.
Change the password
If you are logging on to the application for the first time, then you will be prompted to change the password. Changing password is mandatory for enhancing the security of the user account.
To change the password:
  1. Sign in to AE for the first time. The Change Password dialog appears.
release notes
Figure: Change Password dialog
    Old Password*Enter the current password.
    New Password*Enter a new and unique password.
    NOTES: To set a strong new password ensure the following:
    - Length of the password is between 6-20 characters and has at least one of each of the following:
    - upper case letter
    - lower case letter
    - digit
    - special character from @, #, _, $, !, &
    You will see an error message if your new password matches the previous password.
    - You can modify the password settings through
    Settings → Configurations → Password Policy. For details, see Password Policy section.
    Confirm Password*Reenter the new password.
    * indicates mandatory fields.
  2. Click Change. The new password is saved.
    • After setting the new password, you will be logged out of the application and will need to re-login. After re-logging, the Security Questions page appears.
    • You can set the questions or skip setting. For details, see Set Security Questions.
Reset forgotten password
You can reset the password using the Forgot Password link. However, you cannot reset the password if you have not set the security questions.
You can reset the password in the following scenarios:
  • If you have forgotten the password.
Or
  • If the password is breached, then for security reasons you need to reset the password.
To reset a forgotten password:
  1. On the login page, click the Forgot Password link. The Forgot Password dialog appears.
Figure: Forgot Password dialog
  1. In the username box, provide the name of the user, and then click Submit. The user will receive a link to reset the password.
  2. Click the link. The Reset your password dialog appears.
    reset password
    Figure: Forgot Password dialog: Reset your password
  3. Enter the password in the New Password and Confirm Password box, and then click Reset Password. The new password is saved.
Understand the user interface (UI)
The topic provides an overview of the AE user interface. Understanding the UI will help you in navigating through the application.
alt text
LabelInterfaceUsage
imgToggle navigation menuToggle the navigation menu, that is, hide or unhide the menu.
imgUser profile menuView login details and user profile and change user password.
imgSearchEnter and search for the navigation menu in the Search box.
Use CTRL+K as a shortcut to open the search dialog.
imgNavigation menuSearch for the navigation menu in the Search Menu box.
Click each menu option to work with each menu.
imgWorkspacePerform various actions depending on the selected menu.
Click toggle to hide or unhide the navigation menu.
User profile
After you sign in to AE UI, click the username and view your sign in details the user profile, the application details. You can also change your password.
User sign in details: You can view the details, such as username, user role, and the last login details that includes, date and time.
Figure: User Profile
View Profile
You can view the user profile.
To view the user profile:
  1. Click the User Icon on the top left corner of the AE UI page. The menu appears.
    User Profile
    Figure: User Profile dialog
  2. In the menu, click View Profile. The User Profile dialog appears.
  3. Modify the following fields, if required:
    Email Id: Enter the email address.
    Language: Select the language for localization, if required. Else, the browser language settings are applied, by default.
    Organization Code refers to the Tenant.
Preferences
User preferences help create personalized, efficient, and user-friendly experiences with respect to select settings in AutomationEdge UI.
To set user preferences:
  2. In the menu, click Preferences. The User Preferences dialog appears.
    user preference
    Figure: User Preferences dialog
  3. Select the following field details:
    • Landing Page: Select the preferred landing page that will open when you log on to AE.
    • Default Category for Workflow: Select the category that you want to apply as the default category to the workflow.
      The selected category is applied to the workflows you want to publish through the Process Studio. For details, see Process Studio User’s Guide 🡪 Publish project through Create.
    • Default Category for Catalogue: Select the category that should open by default, when you click the Catalogue tab.
    • Default Page Size for Tables: Select the number of records you want to view on any page with tabular data.
    • Filter Active Workflows by Default on Workflows Page: Toggle the switch to display only active workflows on the Workflows page.
    When you publish the workflow from Process Studio, it is in an inactive state. To view this workflow on the Workflows page, click clear filter. Both active and inactive workflows will be visible on the Workflows page.
    • UI Color Scheme: Choose from the available theme options: Light, Dark, or System.
    The default color scheme of the application is System.
    • Light: Applies a light-colored interface for better visibility in bright environments.
      light
      Figure: User Preferences: UI Color Scheme: Light view
    • Dark: Applies a dark-colored interface to reduce eye strain, especially in low-light conditions.
      dark
      Figure: User Preferences: UI Color Scheme: Dark view
    • System: Automatically matches the theme with your device's system settings.
      light
      Figure: User Preferences: UI Color Scheme: System view
  4. Click Save. The details are saved.
About
You can view the AE application details.
To view the application details:
  2. In the menu, click About. The About dialog appears.
    user preference
    Figure: About dialog
  3. View the following details:
    • UI Version: The AE user interface version.
    • Server Version: The AE server version.
    • Supported Framework Version: The current Process Studio framework.
Change Password
You can modify the password using the Change Password option.
To modify the password:
  2. In the menu, click Change Password. The Change Password dialog appears.
    user preference
    Figure: Change Password page
  3. In the fields, enter the old and new password, and then click Change. The new password is saved.
You can have your branding by setting a logo at the Tenant level. The logo appears on the top left corner on AutomationEdge UI.
Only users with Admin role can set the tenant logo.
To set the tenant logo:
  2. In the menu, click Set Tenant Logo. The Set Tenant Logo dialog appears.
    user preference
    Figure : Set Tenant Logo dialog
  3. Click Choose File, and then select the image that you want to set as the tenant logo. The Preview view appears.
    user preference
    Figure: Set Tenant Logo dialog: Logo selection
  4. Click Save. The selected image appears as the logo in top left side of the AE UI.
    • Click Reset, if you want to change the logo image.
    • Click Close, if you want to close the dialog without saving the changes.
    • The Remove Tenant Logo option appears only if you have set the tenant logo.
What’s new in v<current version>
Click to reopen the Release Notes dialog.
Sign Out
Click to log out of the application.
Use the Search feature to search and navigate to menu and submenu with ease.
The spotlight search allows you to enter keywords to filter and display a list of matching navigation options.
The search matches keywords against the Menu ID, ID, menu title, and any associated tags to the tabs.
To search a menu or submenu option:
  1. After signing in to AE UI, in the left pane, click in the search box OR press CTRL+K. The search dialog appears.
alt text
Figure: Search dialog
  1. Enter the name of the menu that you want to navigate to, for example, configuration. Menus and submenus having configuration in their name are listed.
alt text
  • Use:
    • up to navigate in the ascending order through the search list.
    • down to navigate in the descending order through the search list.
  • Press Enter or click to select the option from the list.
  • Press Esc or click anywhere outside to close the search dialog.
  1. Select and click OR press Enter to navigate to the selected menu, for example, Configurations (Settings > Configurations). The selected menu page appears, for example, Configurations.
alt text
Figure: Configurations page
If you open the search dialog again, then the search history appears in the list.
user preference
Figure: Recent search view
The system displays the three most recent searches in memory for the current session.
The menu allows us to navigate to different features.
MenuMenu optionsDescription
HomeLicense DetailsUse to view the details of the license, such as license type, start date, expiry date, and so on.
UsersUser ListUse to add users with various roles, such as Admin, User Admin, Workflow Admin, Agent Admin, Activity Monitor, and User.
Or
Use to upload new users to AE.
User GroupsUse to add new user groups.
Process StudioProcess StudioUse to register the Process Studio and to apply the Process Studio license to users.
WorkflowsWorkflow ListUse to add new workflow, search, edit, delete, activate, and deactivate workflow.
SharedUse to share workflows with users of a tenant. Sharing workflows, allows other users of the tenant to reuse the workflows in their projects.
InspectionUse to configure rules for workflows.
SchedulerUse to add, search, edit, delete, activate, deactivate, and transfer workflow schedules.
CategoriesUse to create workflow categories and move workflows to different categories.
CredentialsUse to create, edit, and delete credential pools and credentials. You can also move credentials to credential pools.
Holiday CalendarUse to add a new calendar, update, renew, copy, or delete the calendar.
ROI ConfigurationUse to provide measurement metrics at two levels, for the cost and time saved, had the task been performed manually, instead of using automation. The information is used to generate Dashboard reports.
TaskPending TasksTo view and act on the list of pending tasks in the Approvals, Assigned to Me, and Document Reviews tabs.
HistoryTo view the history of completed tasks.
TemplatesTo create or import task templates, as required.
Document MetadataTo create or import document metadata required for the task.
AgentsAgent ListUse to download agents.
Workflow AssignmentUse to assign workflows to an agent.
IP WhitelistingUse to allow agents only from certain IP address to talk to the AE Server.
Agent SettingsUse to enable a setting to include JRE with agent.
File ManagementFilesUse to manage workflow files, centrally.
Allowed File TypesUse to add file types that you can upload to the AE server.
CatalogueCatalogueUse to view and submit workflow for execution.
RequestsRequestsUse to view all the requests submitted by the users and the results.
ReportsDashboardsUse to view multiple reports.
DatasourceUse to create connect to an external database to fetch data for Custom Reports.
QueriesTo create a new query to improve user experience and ensure accurate data entry.
TemplatesUse to define Templates by specifying a database query, the required attributes and format for generating reports.
Email ReportsUse to view reports on dashboards and download as PDF or CSV.
ConsumptionTo generate and view DocEdge consumption reports.
LogsAgent LogsUse to download and view agent logs.
Audit LogsUse to download and view audit logs.
RolesRolesUse to add new custom defined roles and view system defined roles.
Permissions ManagerWorkflow PermissionsUse to assign workflow permissions to users or user groups.
Credential PermissionsUse to assign credential or credential pool permissions to users or user groups.
Report PermissionsUse to assign report permissions to users and / or user groups to various dashboard and custom reports available in AE.
PurgingPurging ConfigurationUse to configure the purge policy and schedules.
ArchivedUse to view the purged records that are archived.
PluginsPluginsUse to view the plugin details.
AE AppsRegistryUse to register an AE app.
App CatalogueUse to view and access the AE app.
Key ManagementTenant KeyUse to manage tenant specific key.
SettingsEmail ConfigurationUse to setup SMTP server or Exchange Cloud configuration for emails.
LDAPUse to setup LDAP server configuration for emails.
Email NotificationUse to enable email notification for users.
ConfigurationsUse to view or set the tenant login, password, and login session control policies.
Vault ConnectionsUse to set the vault connections and retrieve the credentials stored in the vault.
Proxy SettingsUse to set proxy settings at tenant or agent or Process Studio level.
Single Sign-OnUse to configure single sign-on.
Tenant MessageUse to set a tenant message.
Workspace
The area where you can work with various features.
