Work with Plugins
System Administrator manages plugins. Admin has view-only access to plugins except the option to set plugin properties.
Known issue: Plugins are not syncing in the Process Studio due to time difference between the Process Studio and AE server.
View plugins
You can view the plugin details and plugin steps.
To view plugin details:
  1. In the menu, click Plugins → Plugins. The Plugin Utilization page appears.
    Plugins
    Plugin NameDisplays the name of the plugin.
    Version:
    ReleaseDisplays the AutomationEdge Plugin Release version.
    FrameworkDisplays the Process Studio Framework version on which of the plugin.
    PluginDisplays the plugin version.
    CreatedDisplays the date of plugin creation.
    Last ModifiedDisplays the date the plugin was last modified.
    To work with Actions icons: On the Plugin Utilization page, in the Actions column:
    • Select a plugin and then click Plugin steps. The selected plugin’s step details appear.
      Plugin steps
      View the following field details:
      NoDisplays the serial number of the step.
      NameDisplays the name of the plugin step.
      TypeDisplays if the plugin has steps and / or entries.
      Metering UnitsDisplays the units of steps or entries consumed in a workflow or process.
      Click Plugin steps. The dialog closes.
    • Select a plugin and then click Plugin steps. The plugin’s workflow utilization details appear.
      Plugin steps
      Workflow NameDisplays the name of the workflow in which the plugin step or entry is used.
      UnitsDisplays the step units utilized in each workflow.
      The step units add up as consumption of License step units.
Configure plugin properties
You can configure properties of some plugins at two levels, Tenant and Agent.
To configure plugin properties:
  1. On the Plugin Utilization page, in the Actions column, click Configure plugin properties. The plugin configuration dialog appears.
    Plugin steps
  2. View and / or enter the following field details:
    Tenant level property configuration
    Property NameDisplays the name of property for which you can configure the details. For example:
    - <plugin> Runtime Port
    - Ignore white spaces in the path
    ValueIn the Actions column, click Edit and enter the value for the property. For example, for:
    - <plugin> Runtime Port: Enter the port number.
    - Ignore white spaces in the path: Select true or false.
    In the Actions column, click Plugin steps to confirm the value.
    LevelDisplays the level at which the property is applied. For example, Tenant indicates that the updated property will be applicable to all users of the tenant.
    Agent DetailsDisplays the property is applied to all agents of the tenant.
  3. Click Save. The details are saved and applied at Tenant level to all agents of the tenant.
    Plugin steps
  4. To configure properties at Agent level:
    Between property configuration at Tenant and Agent level, properties configured at Agent level will be applicable for the plugin.
    1. Click + Add Property Value. A row to add property appears.
      Plugin steps
    2. Select or enter the details for the respective fields, and then click Plugin steps. The details are saved.
    3. Click Save. The details are saved and applied at Agent level to the selected agent of the tenant.
