Assign Report Permissions
Report Permissions let you control which users and groups can view, modify, or use specific OOTB and custom report templates. For custom reports, you can grant View, Modify, and Use permissions based on the user's role and existing template page access. For OOTB reports, only the Use permission is available since these templates cannot be modified. Permissions depend on the user's role — a user role with template page permission can receive all three permission types, while a role without it can only receive Use permission. This ensures that report templates are shared appropriately, preventing unauthorized changes to custom reports while still allowing broad access to standard reporting.
- When you migrate from previous AE version to the latest version the legacy reports will have the following permissions:
- OOTB reports: Users and user groups will have Use permission.
- Custom report templates:
If the users or user groups have Report Template access, then they will have View, Modify, and Use permissions.
and
If the users or user groups has no access to the Report template, then they will have Use permission only.
To grant report permissions to users and / or user groups:
In the menu, click Permissions Manager 🡪 Report Permissions. The Report Permissions page appears.
In the Report Tab all reports, custom and OOTB, appear in the left pane. The users and user groups appear in the left pane.
Note- To change the view, click the Users tab, users and user groups will appear in the left pane, and the reports will appear in the right pane.
- All: All users and user groups appear in the list.
- Users (
): All users under the tenant appear in the list.
- Groups (
): All user groups under the tenant appear in the list.
: Indicates that the user is member of a group.
In the reports list, select the report to which you want to grant permission, and in the left pane, select the users and / or user groups.
Permissions:
View: Allows users to view template details in a read only mode.
Modify: Allows users to view, edit, and delete the template.
Use: Allows users to create reports using the template.
In the Assigned Permission column, select the permission you want to assign to the user and / or user group for the selected workflow or category. Available options are View, Run, and Modify.
Report permissions assigned
Note-
In the Computed Permission column, view the maximum permissions assigned to the users or user groups or reports.
To remove the permissions granted to users and / or user group, click the respective permission. The permission is struck out and greyed indicating that the permissions are removed.
Click Save. The permissions are saved successfully.
