Surface Actions: Configure OCR provider
  1. In the step, click Configure Provider, the Surface Actions dialog appears.
Surface Actions Configure Provider dialog
  1. In the Tool list, select the OCR provider from the list. Available options are:
  • Tesseract
  • Google Vision
  • Microsoft Azure
OCR provider selection dropdown with Tesseract, Google Vision, and Microsoft Azure
  1. The configuration fields will change depending on the tool you select: Tesseract
Important
Before configuring Tesseract, download the required locale (.traineddata) file from the web. The System Administrator can upload the file through File Management → Files on the AutomationEdge Server. English language is available by default.
For Tesseract, configure the following field details:
LocaleSelect the required language for OCR processing from the list.
Notes:
• By default, only the English language file, that is, eng.traineddata is included in the tool.
• To support other language(s) in the Locale list, place additional language files in the tessdata folder within the folder where the JAR is placed.
For example, hin.traineddata for Hindi. The languages of added files will be available in the Locale list.
• Make sure the language file follows the format and is compatible with Tesseract OCR.
Allowed format: <lang-code>.traineddata
For details, see: https://github.com/tesseract-ocr/tessdata/tree/main
Google Vision For Google Vision, configure the following field details:
Google Vision OCR provider configuration fields
References:
Api KeySpecify valid Azure Document Intelligence service key.
• Select Accept value as variable/static to use the API key as a static value or from an environment variable in the API key box.
• Clear the checkbox to use the API key from the previous step.
LocaleSpecify the language code, for example, en.
Reference link: https://cloud.google.com/translate/docs/languages
Microsoft Azure
For Microsoft Azure, configure the following field details:
Microsoft Azure OCR provider configuration fields
To create resources, see: https://learn.microsoft.com/en-us/azure/ai-services/document-intelligence/how-to-guides/create-document-intelligence-resource?view=doc-intel-4.0.0
For Microsoft Azure, the following field will be available to configure:
Notes:
API EndpointSpecify the valid Document Intelligence service endpoint.
Notes:
• Select Accept value as variable/static to use the API Endpoint as a static value or from an environment variable in the API key box.
Or
Specify a BCP 47 language tag, for example, en-US.
For details, see: https://learn.microsoft.com/en-us/azure/ai-services/document-intelligence/language-support/ocr?view=doc-intel-4.0.0&tabs=read-print%2Clayout-print%2Cgeneral
