Dropbox: Register App & Generate Token
Register App
Visit the Dropbox Apps registration portal using Developer's Portal.
Sign in with Dropbox credentials.
On the page, click Create App. The app creation page appears.
On the page, complete the following process to create an app:
i. Choose an API.
ii. Select the type of access you need.
iii. Enter a unique app name.
iv. Click Create App, and then provide redirect URIs, such as 'https://automationedge.com' or 'http://localhost:8080'.
v. To provide required permissions on App registration portal, click Permissions tab and provide the appropriate permissions defined in step documentation.
Generate Refresh Token URL and Run in browser
Call the following API in browser by adding the App Key and allow app to generate the authorization code:
https://www.dropbox.com/oauth2/authorize?client_id=<AppKey>&token_access_type=offline&response_type=code
Click Continue, and then click Allow.
Copy the authorization code from Access Code Generated.
Note:The authorization code is valid for short period of time.
Create Post request in postman as follows:
POST https://api.dropboxapi.com/oauth2/token
Headers:
Authorization:
Select basic auth and provide
Username: App Key
Password: App Secret
Body:
Select -> x-www-form-urlencoded
code: <authorization code generated in previous request>
grant_type: authorization_code
Redeem the Refresh Token.
