Office 365: Assign License
This step assigns a license to a user in your Microsoft 365 tenant. You provide the user's email and the license SKU to assign. Use this step in onboarding workflows that provision software licenses for new employees, or in automation that assigns licenses based on role or department.
Permissions Following permissions are required to assign license in Office 365:
Permission TypePermission Name (from least to most privileged)
ApplicationUser.ReadWrite.All, Directory.ReadWrite.All
References
https://docs.microsoft.com/en-us/graph/api/user-assignlicense?view=graph-rest-1.0
  • Product names and service plan identifiers for licensing. Click the link to get the Subscription name or SKU ID (GUID) and apps (Service plans included).
  • To get the user ID, see the following screenshot: alt text
No.Field NameDescription
1Step NameName of the step. This name has to be unique in a single workflow.
Connection:For details about app registration, see O365 App Registration, Authentication, and Permissions in Azure AD
2Tenant IDTenant ID of Microsoft Account.
The data type is string. This field is mandatory.
3Client IDClient ID of the Application created in Microsoft Account.
Client Secret:
4Accept Value as variable/staticLeave checkbox unchecked to accept Client Secret value from a field in the previous steps of the stream using a drop down list.
Else enable checkbox for Client Secret field to appear as Text box.
5Client SecretSpecify the Client Secret generated in Microsoft Account.
Client Secret is entered using a widget. The widget handles both Text (static value or environment variable) and Combo (drop down containing values from previous steps).
If checkbox above is enabled, Client Secret field appears as a Text box and accepts static or variable values. Else if checkbox above is disabled, Client Secret field appears as a drop down to select fields from previous steps.
The data type is secure string. This field is mandatory.
6Button: Test ConnectionTest connection with Client ID and Client Secret provided. Verifies whether the connection is established or not.
Note: For the purpose of verification, fields coming from previous steps are not allowed since field values can only be accessed when workflow is in running state. Static values and environment variables are allowed.
Input Fields:
1Subscription Name (SKU Name)/SKU IDSelect the subscriptions available to the tenant.The data type is string. This field is mandatory.
2Button: GetDisplays list of all the available subscriptions.
3User Email/IDProvide the email address or user ID of the user for which the license is to be assigned.
4Button: GetClick to Display the list of all the available user’s emails.It Can only fetch the top 100 User Emails.
5Apps To Be DisabledSelect the apps to be disabled under a particular license from the table.
Note: In the Apps To Be Disabled table, if both cells contain values, priority is given to the Static Apps column cell.
6Variable AppsSelect input from a previous step or as workflow parameters in the column, which will set the apps to disable from the license to be assigned.
7Static AppsClick on a cell in the column, which will populate the apps to be disabled from the license to be assigned.
